Kenmore elite will not start
Dishwasher Control panel buttons will not light and dishwasher will not start.
What would you replace the thermal control swith or door switch?
Here is your tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208537797.pdf
Next the "thermal control switch" (thermal fuse) as they are a known problem area. If blown be sure to replace the wiring harness which should come with the fuse.
Then the door switches.
On the Dishwasher Control panel the control lock is lit.
What would you replace the power mod. control board, thermal control switch or door switch?
— Begin quote from invergo;214424
What is the complete model number of the dishwasher?
— Begin quote from Jsibey;212843
Model 665.15891792
What do you think the problem is. The dishwasher is 12 years old and I’m not sure if it an "elite".
thank you, Jo Invergo
Jo,
The control board for this dishwasher is no longer available. Looks like it’s time for a new dishwasher.
