Kenmore gas dryer not heating
Model 97591240
sensors mounted on the flame chamber and the igniter show continuity but get no ignition/glow from igniter.
All vents are clear. Gas is on and to the dryer. Power is on, drum turns and timer cycles properly. suggestions?
check the black valve coils for continuity
— Begin quote from Qtip;191484
valve coils check ok, 500 to 1000 ohms
Hi, John.
Most likely the problem is bad thermal fuse.
It’s located on the blower housing.
With the dryer unplugged get the toe panel off , take one wire off the fuse and check for continuity. If it’s open - replace the fuse.
The thermal fuse AP3133489
Thank you. Post the results.
