Kenmore Gas Dryer with not heat - 70 series
I have Kenmore Dryer 70 series. The dryer spins with no heat. I believe the heating element is not working and needs to be replaced. The symptoms are exactly the same to that of another post of the similar model dryer but the electric model.
http://forum.appliancepartspros.com/dryer-repair/43719-kenmore-70-series-no-heat-wont-shut-off.html
As in the post above the machine does not shut off.
Can sometell tell me what I need to replace? I look at the diagram and I could not ID the part. Also is it hard to do. Are there instructions on the web on how to do this?
