kenmore HE pump replacement
I have to replace the pump on my Kenmore HE2 washer model number 110.4752602. Do you have to get at the screws from underneath to replace the pump? I cant see how to remove it. Thanks
The instructions are attached to the reply.
A big thank you to Gene for the downloadable step by step instructions on removing the HE2 drain pump. I am not the handiest guy, but I was able to take out the pump, remove a rubber band that had wrapped itself around the impeller blade, reinstall the pump, and get back to doing laundry.
