Hopefully you can help. Our ice maker stopped producing ice. More specifically, it stopped filling. This happened before, and it was due to our filter not being changed out and the maker itself breaking. Now, the filter is fine (it indicated that we needed to order, but not replace. When it stopped this time, I went ahead and replaced it in case that was the issue), but it’s still not working. Looking through the threads before, as well as online sources, I’ve diagnosed that it’s either the ice maker itself, or the dual valve in the back. I went ahead and replace the valve, since the maker was going through the entire cycle, but just not filling. The LED’s are indicated good communication (2 blinks, 1 sec pause, 2 blinks, 1 sec pause, etc.) and when the door light switch is closed and the maker is in harvest mode, the LED blinks on and off in 1 second intervals. Do I have a bad ice maker? or is there something else bigger wrong. Any help would be greatly appreciated.
Related topics
Ditto- Ice maker not working | 9 | 5506 | April 25, 2011 | |
Ice Maker Not Working | 1 | 2173 | March 25, 2011 | |
Ice maker not making ice/no water in tray | 0 | 1849 | October 2, 2011 | |
Kenmore ice maker not making ice | 1 | 592 | April 27, 2015 | |
ice maker doesnt work | 1 | 596 | December 16, 2013 |
