I have a Kenmore refrigerator that is not making Ice. I checked the water valve and it had a bad solenoid, so I replaced it. After 24 hrs it still is not making Ice. I did check to see if the water line was stopped up and it is clear. The water tray in the ice maker was full when it stopped producing ice(still is and it is frozen ) The lever is in the correct position to make ice.
What can I check, or what might the problem be.
Thank you
ldutton
