Two days prior to this happening the dishwasher worked fine. I tried to use it and it filled with water started to wash and stopped. At this point, I could not drain the water, but if I tried to wash again to get it to run, it would fill up with water again, but did not switch to wash.
If I let it sit for a few days and try to drain again, it will switch modes and attempt to drain and then freeze. It’s not humming and nothing seems to be stuck there.
I’ve tried different cycles and nothing, it starts switching and then nothing, you can hear to click into different modes, but something seems to block it from continuing.
Also, the bottom has this then net that prevents objects from getting inside too, I’ve checked that.
I was told it’s the control panel that might not be responding, but nobody is 99% certain.
Please help me!
