Kenmore oven F codes?
My Kenmore oven/range is showing F7 code. It won’t respond to pushing cancel until it has been beeping more a minute or two. I think I might have messed up the control panel when I steam cleaned it. How do I remove the panel to dry it out, and do you have an instruction / repair manual for this model?
Hello,
My husband ordered and replaced a white panel part that the computer touch pad fits on as the little inside clips on this panel were broken.(cleaning lady trying to clean it accidentally broke it)
He peeled off the computer touch pad off the old panel and affixed it to the new panel. Well, now a few buttons on the touch pad will not work. The Reheat, beverage, cook power, #3, #8, vent/fan, timer set, and baked potato buttons do not work. Do you have any clue as to why?? It worked perfectly before we changed this panel.
Also, should we use a certain glue to adhere the computer touch pad edges back on the new panel?
Thank you for your help!!
Wendy
