Kenmore Range
No heat in oven when trying to bake or broil. Clock and controls work.
Hi.
If you feel Ok to do the "life" test then get access to the control board/clock.
Locate the BK, BRL, L2out contacts at the control.
Set the oven to Bake and using the multimeter check if you have 230VAC between BK and L2out.
Set for broil and check between BRL and L2out.
No 230v - replace the clock.
The control board 316207511
The overlay 316220841
Thank you. Good luck. Post the results.
Simon.
— Begin quote from Simon / APP Team;727455
Hi.
The control board [part]316207511[/part]
The overlay [part]316220841 [/part]
Simon.
Did this exact test and got no reading, so I ordered the control board/clock. Took 10 mins to pop it in and now the stove works like a charm. Thank you!!!
You are very welcome.
Simon.
