Kenmore refrigerator leaking
My Kenmore refrigerator, model # 253.61714406, has been periodically leaking from underneath the refrigerator ever since it was moved from one house to another. (There is no ice maker.) It never leaked before it was moved. What is the likely problem?
The water is probably from the defrost cycle.
Pull the unit away from the wall.
If it has a lower cover remove it so you can see the compressor.
The compressor should have a drip tray on the top of it.
Check that the tubing that comes down from the freezer is draining into the drip tray.
Inspect the tray for cracks etc.
Click on the part’s picture for more info and views of it.
AP3777950
