Kenmore side by side freezing up
My kenmore side by side freezer is freezing up and causing refrigerator to get hot, I have tried cleaning the condenser coil and evaporator to but after about a week it is frozen up again, what should my next step be? thanks
You have an Amana refrigerator, go to web site %url% and do the manual defrost procedure for an Amana.
If the compressor stops, but you get no defrost action, you most probably have a bad defrost thermostat ( your adaptive defrost board is ok) clipped to the top of the evaporator, just replace it using this parts site. If you have a meter you can check the defrost heater, most probably ok.
