Kenmore Soap Dispenser
The soap dispenser door on my Kenmore Dishwasher kept hanging up so I removed the inner panel to the door. The lever that opens the door was packed with undissolved soap so I removed the lever and a spring came out. Does anyone know how to get this spring back in to the position it needs to be in?
The following may help.
http://www.applianceaid.com/soap-door.html#ge_closed
I figured the hook end of the spring fit in to the cutout on the lever but where does the other end of the spring ( straight end ) go to put tension on the spring? I can’t get the picture in the link to focus clear enough to see it. Attached is a picture I took of mine. I have the straight end banked up against the post that sticks out. Problem with that is that now the door won’t lock when it is closed and every time I open and close the door it pops the spring loose.
