Hello all, Kenmore 106.55502400 made by Whirlpool. Side by side. Icemaker stopped working. Through door water working fine. Replaced filter to make sure pressure was good. Without disconnecting water tubes I removed solenoid valve far enough to test two solenoids & both showing approx. 225ohms which some other forums/threads indicate the solenoid itself is probably OK. **Water tube to feed the icemaker runs up the back of the cabinet on the outside of the cabinet, so I can see that the water supply tube is not frozen. Should my next step in troubleshooting be to disconnect the icemaker water supply tube, then turn on the icemaker to see if the solenoid/valve is really working? Wouldn’t I get water flowing through the tube? Anybody out there have any experience with this Kenmore made by Whirlpool & have seen this failure? Other suggestions would be appreciated on what to look for. Or, if anyone has experience with this type icemaker & knows of other parts I can check that are prone to failure. Thanks!!
You can find the troubleshooting instructions in one of our previous posts: http://forum.appliancepartspros.com/refrigerator-freezer-repair/8566-water-ice-maker-quit-working.html
Perform the troubleshooting and post the results.
[SIZE=2]We have the same problem with our Kenmore. If the freezer door is not closed tight, the water filler to the ice maker will freezes up. When this happens, no ice maker but the water in the door works fine. Turn off you refrigerator for a few hours and it will be fine. We turn ours off over night. With grandchildren this has happened many times with our side by side (106.52602100)
[/SIZE]
wktcknet,
Based on your report the ice maker is bad and has to be replaced.
- The part number for the ice maker is AP2984633
