Kenmore Ultra Wash dishwasher Model 665.16719 has a "Cancel/Drain" light stuck on and will not reset, and unit won’t run. Light was first solid then flashing. Disconnecting power for several minutes and trying reset procedure (Hi Temp Wash - Air dry - Hi Temp Wash - Air Dry) changes nothing. Looking at control board I don’t see anything obvious (no burned components, connector issues, etc.). How can I diagnose further to identify the culprit? If applicable, how can I separate out the control panel circuit board from the push button assembly (ribbon & connector) in the control panel? Also, label on the circuit board assembly reads "Whirlpool Corp. p/n 3384563 and UPC # 8456300057755. Appreciate any insight you can provide. Thanks.
Related topics
Kenmore Ultra Wash - Completely stopped working, no lights | 1 | 1791 | December 13, 2008 | |
kenmore ultrawash dishwasher | 1 | 1267 | February 13, 2011 | |
Kenmore 66515712000 blinking "washing" light | 2 | 2986 | December 1, 2009 | |
Kenmore ultra Cancel/Drain light is Red | 1 | 3568 | October 1, 2012 | |
Kenmore Elite Flashing "Normal Wash" light. Will not Run/Reset/NADA! | 7 | 18934 | October 6, 2010 |
