Kenmore washer not agitating
Washer appears to complete all cycles…but doesn’t agitate.
Where do I start?
After it stops filling with water does it make any noise? Is the motor running/humming or is it just quiet until it gets to drain/spin mode?
Eric
Hi.
If the motor is running in agitation and the washer spins remove the agitator and check if the transmission shaft is rotating.
If it does - replace the agitator, if not - transmission.
If the washer only drains but no spin or agitation - check the motor coupling.
Here are the breakdown diagrams and http://www.appliancepartspros.com/brake-clutch-gearcase-parts-for-whirlpool-lsq9600lw0.html
Post the results.
Simon.
