Kenmore washer not spinning, makes grinding noise
I just bought this washer used and it makes a grinding noise during the spin cycle and the agitator does not agitate at all. Could this be a simple problem as the coupler needing to be replaced on this particular model? Any suggestions?
BINGO!!! Here is a website that will give you step by step instruction. http://www.davesrepair.com/DIYhelp/DIY285753.htm Tom http://www.applianceeducator.com
