Kenmore washer tub repair
I found that a penny had been launched into the plastic tub of the washer and caused a hole, leaking profusely.
I took the tub out and separated the halves, and want to know if the plastic is repairable with fiberglass or perhaps with a PVC glue and plug.
The hole is actually the thickness of a penny and almost as wide, so it is a slit. I figured I could repair this, but I am unsure of the type of plastic and if fiberglass or epoxy will stick permanently to it.
Any ideas?
Thanks, Doug
