Help, my Kenmore washer will not spin, at all. It washes fine, drains fine, yet when the timer moves to the spin cycle, nothing. The motor does not even try to run either, the only sound is the sound of the timer. You can manually move the timer ahead, and still no spinning ! Is there any type of relay switch that I should be checking.
What is the full model number of the washer?
— Begin quote from ApplianceJunk;641445
The full moder number is 110 92582100
stock # 25821 serial # cd2941244
