Hi, the washer won’t drain or rotate the drum (quit with water & clothes in it). I put it on Drain&Spin and it will run the pump a few seconds when I push the start button (turning off each time). I was able to get the water out of it this way. The first thing I checked is the motor control plugs because they’ve come off before (& I have a zip-tie around it to keep the lid down) but the plugs are all OK. I took the front panel off and the plugs are all in. What next? Does this thing have diagnostics?
Related topics
Kenmore doesn't spin or drain | 1 | 1179 | October 18, 2010 | |
Washer won't drain | 0 | 1045 | November 20, 2007 | |
washer won't drain or spin | 2 | 1016 | April 3, 2012 | |
no spin, washer water won't drain | 2 | 2611 | July 18, 2009 | |
Kenmore 110 washer wont spin or drain motor hums | 1 | 2400 | March 13, 2011 |
