Kenmore washer won't run
I have a Kenmore front load washer, model 48102701 and I can’t get the washer to start when I press the start button. It simply continues to flash lights. Already Tried pushing the start button to get an error code. It’s beeping three times. Please help!
Look inside the lower service panel and you will find some tech notes. You may be getting an error message and the tech notes will tell you how to interpret it.
Focus your attention on the door lock assembly, its wiring and the control unit. That is likely where your problems lie.
