Kenmore washer
Kenmore washer leaks from back upper corner during fill cycle
Most likely it’s leaking from the water inlet valve or the inlet hose. Remove the washer cabinet (the instructions attached) to figure out which part is leaking.
  • The water inlet valve [part]AP3094541[/part]
  • The inlet hose [part]AP2907478[/part]
