I need help with this washer that won’t spin or agitate. It just stopped in the middle of the rinse cycle (but with no water in it) and won’t start again. I took the whole thing apart and can’t find the problem. When I bypass the lid switch for the spin cycle it just makes a humming noise.
I can spin the metal tub with my hands one way but it kind of whirs while I do it. I can sort of spin it the other way but it makes a squeaking noise.
I took off the pump and the outlet hose from the tub and they’re fine. I took off the motor and it spins fine. The coupler is fine too.
I took off the transmission but I’m not sure what to look for. I pulled the shaft out so the metal circle with the spring thing wouldn’t match up with the plastic arm that turns the tub and I could spin the transmission freely in both directions. In one direction I could see the shaft turning one way then back the other slowly, and in the other direction I could see the shaft turning faster the other way. With it on its side I could turn the tub from underneath using the plastic arm.
I took off the plastic parts from the agitator but couldn’t get off the metal nut with the 4 slots. There wasn’t anything stuck underneath the plastic but that’s all I could figure out there.
Does anybody know what else I can try? I don’t want to throw the thing out if I can fix it, but I’ll just buy something newer if I have to spend a couple hundred dollars to bring somebody in that might not even get as far as I did.
