Kenmore won't spin, but hear motor
Hello- I just bought a used Kenmore washer, and after lugging it down to the basement, discovered it doesn’t work. It fills, and I can hear what sounds like the motor, but no spin or agitation. I read the response from Gene to someone about a broken motor coupling, and wonder if there’s a good way to test that visually or by hand.
EDIT:
When I say it won’t spin, I don’t just mean the spin cycle- I mean it doesn’t turn on its own at all.
Any suggestions?
Thanks in advance–
Hi Nat-
Thanks for the quick response. I just checked, and the "legs" seem fine. I can turn the coupling by hand. I also realized that I was looking in the wrong place for the model number. It’s 110.20412990.
Any other ideas? Thanks again-
did you check both white pieces?
if both look ok then replace the coupler, and pump(making sure clips are good & tight.
Replace the front panel, before you put the top back on locate the wires that connect to the lid switch.
If I gambled at all, I would say the lid switch and probably the pump need replaced about $50 in parts for a ball park figure.
If you use the jumper on the lid switch it should agitate and spin(complete a cycle), if not you may have other issues. If there is an obstruction of the pump is out it won’t drain… If you can determine if it’s the lid switch a bypass would be cheaper for you. The pump if it doesn’t drain the water out is around $35 part # 3363394.
The model number you posted does not come up. Verify and repost it.
Check all wheels, slides and bracket assemblies on both sides according to the diagram.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=1243071&&model_id=5151403
