The Kenmore gas dryer will only run if the Press-To-Start switch is held down.
Your start switch is probably out, replace it. http://www.appliancepartspros.com/part_details.aspx?part_id=2975301&pn_=3395382
Nat
Are you referring to the motor relay or heater relay. They are the same part number. Thanks
