My slide in range just recently began acting up. Some of the keys on the keypad no longer work. Also the oven appers to "lock up" after running for a while and none of the keys will do anything. I actually have to turn off the circuit breaker to shut down the oven. If I change the clock/EOC will that also fix the keypad problem.
Thank you.
