KichenAId Washer
The timer just stops in the middle of a cycle. I can start it and it will fill and start to agitate then its stops. I can move it to rinse and it will work for a little bit and then quit. It will not drain or spin.
Sounds like your lid switch is either bad, or it’s not being securely activated. Here’s the part number for t he switch: [part]AP3100003[/part]
