Kitchen aid control board
Our unit started smoking.It smelled like burning plastic.I took the unit out and found a scorched control board.I found evidence of corrosion on one of the wires housed within one of the plugs.Could this corrosion be the cause of the board shorting out?There was no evidence of "live" moisture other than the green corrosion on one wire.Should I change the wiring harness as well?I replaced the control and the unit runs fine now but I want to head off any future problems.Shouldn’t a dishwasher have better moisture control for the circuitry?It’s a fully integrated door,so there are not a lot of entry points for water.
— Begin quote from abtrman;196909
1)…Could this corrosion be the cause of the board shorting out?..
2)…Should I change the wiring harness as well?..
  1. Yes, it is possible.
  2. I believe a new wire terminals will be enough.
— Begin quote from Gene;196959
Thank-you for the advice I will replace them shortly.(pun intended).
