Kitchen Aid double oven door would not unlock after self cleaning. Sears service replaced Thermal sensor. Now oven will not heat. Sears wants to install new Control panel $465.00. Your service has this part on back order with no stock listed any time soon. Internet has this as a very common problem, but cannot find solution. Some sites state to replace thermal fuse,but your on line tech support says this model does not have a fuse. Can you offer some help? Thanks
Here is the wiring diagram
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%204451879.pdf
It does show a thermal cut off on both the upper and lower ovens.
Did it heat up after the sensor replacement?
Are both ovens not working?
If it never had heat again I would suspect the thermal cut off.
Here is a manual which may help
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/cf019bc87b565af78525734400549998/$FILE/4317416%20Double%20Wall%20Oven.pdf
Yes it can be replaced but first you have to find out if it is causing the problem.
Thank you so much. Sears service replaced the Thermal control and I am up and cooking! Very helpful
