Kitchen Aid ice maker does not work
Hello,
I have checked for voltage at test points L&N at the ice maker & have 101 volts, I then proceeded to jumper test points T&H to check for motor operation, heat element & water but nothing happens. Red LED on the door flashes 2 times when door is open & stays red when I hold the flapper down. While testing I also noticed a 1 1/2" piece of ice had the water supply tube at the top of the freezer above the ice maker completely plugged but after it thawed & fell out it made no difference.
So what does this sound like could be the problem?
Thanks,
Paul
