Kitchen aid not cleaning dishes have error codes
The dishwasher doesn’t complete the cleaning cycle. The diagnostic code errors are 6-4 6-1 6-2 3-3. During the diagnosis check water fills, can hear water spraying and arms turn. The heating element gets hot. The washer drains. During real wash cycles it doesn’t always appear to have enough water. The washer usually stops before the drying cycle.
Any suggestions are welcomed and appreciated.
Thank you.
Could your water be getting siphoned out by the drain?
I used to see this once in awhile. The drain is hooked together in such a way that at some point in the cycle, usually right after it drains and then starts refilling, the water is siphoned out as fast as it fills.
I used to always carry a siphon break in my vehicle just for these rare drain problems.
