Kitchen Aid oven not heating up
My parents own this kitchen aid oven and today the oven part quit working. The burners work fine and I have read other threads about a fuse needing to be replaced which seems consistent with what is wrong with the oven however, I am just curious where this fuse was found? I do not see any other wiring diagrams and I’m not sure where the current wiring diagram ‘Power Board Unit’ is located. Do I need to remove the entire back of the oven to get to it? I have removed the center panel (smaller one) and found a small PCB with some capacitors on it labeled V1, V2, and V3 and also wher the power cord connects to the oven but it doesn’t seem that this is on the wiring diagram on the small panel. Any ideas?
Thanks!
