I have a superba kitchen aid electric dryer which originally had no heat at all, I repalced the high temp thermometer and I was able to use the dryer for 2 days with heat before I again had no heat.
I then replaced the cycling thermostat now The dryer only gets warm. I intend to buy another high temp thermo becuase I believe it went out again.i’ve read that the cycling thermo causes the high temp thermo to go out which is the reason I am have repalced on and will be replacing the other soon.
Am I missing a step or should I have full blown heat after I repalce that final high temp thermo?
