Normal and Rinse Only lights blinking. Disconnected and reconnected ribbon cable, and cycle started fine. After a few minutes, pressed cancel/drain which also worked. Maybe I shouldn’t have canceled it as now Normal light blinks and won’t start. When you press start, the rinse only LED starts blinking too. Seems a little like waverider’s post. I guess I have to find teeny tiny probes to test the cable? Btw, this happened 3 months ago and disconnecting cable worked until now. Any help greatly appreciated, don’t want to buy a new one. Thanks!
Related topics
Kitchenaid -need help interpreting diagnostic | 2 | 2027 | June 17, 2015 | |
Start/Resume Light Blinking - Dishwasher Not Starting | 2 | 19161 | May 6, 2009 | |
KitchenAid Dishwasher blinky LEDS now not blinky | 2 | 2378 | June 28, 2009 | |
Kitchenaid Dishwasher KUDE70FXSS5-Cancel/Drain light lights up after I try to run dis | 1 | 2311 | November 26, 2014 | |
"normal" cycle light is blinking, all other lights are on dimly&won't run | 1 | 2451 | October 24, 2010 |
