KitchenAid Burner Replacement
While cooking I discovered that the right rear burner was no longer heating. I replaced the pot on the left front burner which immediately became hot and continued cooking. Later when I returned it too was no longer heating. The left back burner and the right front burner continue to work.
Before I order new burners I would like to know if there could be another explanation for this problem. Should I do further checking before ordering new burners?
John Scott
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=KECC501GBL0
Here is a wiring diagram and manual
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%203191793.pdf
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/73a244d6c58b438085256a8c005b310a/$FILE/4317269.pdf
[COLOR=Blue]
Should I do further checking before ordering new burners?[/COLOR]
Yes, check the wiring, could be a wire has burned off.
Also check the elements with a meter.
Just because both give the same symptom does not mean they have the same cause re: one could be burned out and the other may need a new infinite switch.
icemaker fills and freezes but won’t come out, it makes noise like it’s trying
but the coil on the bottom of tray doesn’t seem to be working. i don’t know if i can replace the coil or icemaker or is the problem elsewhere??
thanks for any help!!:slight_smile:
