Kitchenaid Dish washer begins to slowly fill up after cycle is completed inlet valve?
After the full cycle is completed there is no standing water in the bottom of the washer so it IS draining completely. After sitting for a few hours I notice the bottom of the washer starting to slowly fill up with water, could this be the inlet valve assembly? I’m guessing that the inlet water is bleeding past the shut off and gradually filling the washer, but I’d like someone else’s opinion to be sure.
Hi.
You are on the right track. This is you part
W10158389
Here are the breakdown diagrams and http://www.appliancepartspros.com/fill-overfill-parts-for-whirlpool-kudj02crbs1.html
Post the results.
Simon.
