KitchenAid Dishwasher Door not Closing and Leaking
This morning my dishwasher door would not stay closed. It would latch and then pop open shortly after starting a cycle. I checked that the unit was level, raised the front feet, etc. I ended up following advice on a forum to insert a piece of wire through the latch. The door held closed fine. Problem now, the right side of the door leaks. I can hear that the door is not getting a good seal on the right hand side. The latch should be made to secure the door and hold it in place without the wire.
Please let me know if there is a replacement latch that would address both problems.
thanks!~
