Kitchenaid dishwasher motor removal
The pump or motor is very noisy. I’ve disassembled and cleaned the impeller and grinder from inside the unit. Can I replace the motor and pump assembly without having to pull the whole unit out from under the counter? Are there any service manuals that show the steps? Thanks.
You have posted on the clothes washing Forum. If you will re post on the diswasher Forum I am sure someone can help you.
