Dishwasher has been running normally and suddenly nothing. No lights no power. Nothing. Checked circuit breaker and that’s fine. Could it be the dishwasher fuse?
If so, what do I do?
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=kuds01djss0
Yes, it could be the fuse (item 6 in the Control Panel Parts section)
If it is blown be sure to use the new harness.
Also if you click on a part’s picture a new page will open often with more info and a Q&A section about that parts.
Also have see problems at the wire nuts that connect the unit to the house wiring.
May also be a bad door latch switch.
