KitchenAid Dishwasher
I have a KitchenAid dishwasher and I think the push button control panel is on the fritz. During the cleaning cycle, the "Normal Wash" will blink and sometime the "Cancel" button will flash.
Is there a way to reset the board?
Thanks in advance for your help.
Tommy
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=KUDL03IVWH3
To reset the board remove power from the unit.
If hard wired in flip the breaker off for a couple minutes.
Denman,
Thanks for the quick reply. Based upon the symptoms I described, does it sound like the control board or could it be something else? What are the typical diagnostic steps for this unit?
Thanks again.
Sounds like a control board problem even though I do not see your symptoms in the tech sheet.
