Kitchenaid dishwasher
my kitchenaid dishwasher has no power, panel does not light up at all, trying to find a wiring diagram to help, does anyone know where i can find one. Thanks.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=KUDR24SE
As you can see there are a number of diffrent units in this series and it looks like your model number is 3 digits short.
Following is a tech sheet for a KUDR24SEBL1
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%209743409.pdf
The most likely cause of no power is a blown thermal fuse, Item 22 in Section 3. Be sure to use the new harness that comes with the fuse.
Next would be a bad door switch or the latch not activating the switch.
Also could be a bad wiring hook up. Have in the past had a number of people with problems with the wiring at the wire nuts. I remember it as it was strange to have several with this problem in a short time period.
Thank You, The Whole Model Number Is Kudr23seal3, Hubby Checked The Thermal Fuse, We Think That Is What Is Wrong And Ordered A New One. I Appreciate Your Help.
