Kitchenaid double oven
Upper oven will not heat up. All lights and dials work, but no heat
— Begin quote from riccole;51268
Upper oven will not heat up. All lights and dials work, but no heat. Is it the thermal disc and how do I replace it?quote]
Gene, I too have an issue very much like this one. You had helped me a couple years ago when this oven locked up during it’s first cleaning. In that case the oven blew the thermostat, the line fuse to the board and the board! Ouch. Now that these repairs were done for about a year, the upper oven has now just stopped heating though I am able to use the lower over without a problem.
The control board activates the oven and shows it is heating just never heats up at all. What is this re-settable thermodisc you discuss in this post? Is it involved in the wiring of my unit? IF not what other tips can you give me to troubleshoot this matter?
Thanks, Tom
P.S. the diagram on the previous post does not come up so that didn’t offer me any help.
