The left double burner will not heat but the power light remains on constantly. How do I get to the inner workings and can I repace the component(s) easily
The model number you posted is incomplete. Verify and repost it please.
The model # is KECD865HBL2; serial # is XK2901021
Most likely the problem is a bad infinite switch for this burner.
In order to access the part the cooktop has to be removed from the counter first. Remove all knobs. Then remove the screws around the burner box and carefully pull up the glass top.
- The infinite switch AP3672660
The new switch comes with the installation instructions.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=264234
