Kitchenaid F1E6 error code-erc..How to access
Have a 2 year old gas Kitchenaid range. Getting the F1E6 error code when trying to turn on the oven. It appears after about 1-3 minutes, after the oven already is starting to heat up.
I went to access the control board and did gain access, but could only rotate the panel up, not actually detach the upper lip from the range. I accessed it by opening the oven door and removing the philips screws. I unplugged the ribbon and repluged with no luck. I did put some stress on the sides of the panel. What step am I missing?
Do you think I need the control board or the membrane? I have not had a chance to run your test since it is at our vaction home (no internet). I was hoping the fact that the codes did not appear until the oven was on might help us diagnose.
Thanks for you time.
Dan
Thanks for you help!
