Kitchenaid KSRS25IKSS01 Evap Fan Constantly Running
Hi All,
I’ve been having an issue with my evap fan constantly running in my Kitchenaid KSRS25IKSS01. I do see that the compressor fan cycles on and off. I also checked the evaporator for ice buildup and everything looks or. It only has a thin layer of ice. The temps in the freezer are at 0 (as low as my temp gauge will go) and 36 in the refrigerator. I tried to increase the temp by sliding the refrigerator to cool instead of colder and the fan did not shut off. Does this look like an issue with the thermostat? If not what else could it be?
Edit: If it helps, I moved the dial one tick down on the freezer setting and both fans went off. Ten minutes later the fan came back on even though I didn’t open the doors after changing the setting.
