I have a new kitchenaid dishwasher - just out of warranty - KUDE48fx that runs for a few minutes and then shuts off. The green light was blinking in multiples of 4 and not working at all, but reset electronic pad with the 1,2,3,1,2,3,1,2,3 sequence and it will start a cycle now. However, it will only run for a few minutes now and then just turns off. There is usually water in the bottom of the DW, but will drain if the drain button is pushed. I lowered the upper rack the last time I tried to run the DW - the upper arm does sit well into the area at the back of the DW though. We did have a power outage recently so not sure if that did something either. Any thoughts/help would be greatly appreciated. Thanks!
Related topics
Kitchenaid Dishwasher Not Running KUDS25SHWH0 | 2 | 1663 | November 13, 2014 | |
KitchenAid Dishwasher won't start | 1 | 2734 | November 20, 2010 | |
Kitchenaid dishwasher help? | 1 | 1030 | November 28, 2010 | |
kitchenaid dishwashet wont run full cycle | 1 | 1280 | August 17, 2014 | |
Dishwasher starts but after a minute goes to Drain/Cancel and shuts off | 1 | 2122 | January 9, 2015 |
