KitchenAid KUDS01IJWH0 only runs cycle number 2 and 1
I’m just stumped with this dishwasher, too me it still seams to be the control board, but I have tried 2 new ones now.
1.Replaced control board and heater element
2.Replaced check valve rubber piece
After replacing the heater and control board unit ran 1 cycle and blew the thermal fuse.
3.Replaced thermal fuse and issue returned to original problem
4.Ordered another control board and replaced
issue is still the same as below
Here is the description of the issue:
If the start/repeat button is pressed after selecting the wash cycle all lights clear and the unit does nothing. If the start button is pressed again it will indicate cycle 2 and run 30-60 seconds then indicate cycle 1 for 30-60 seconds then stop. I can here the pump running and if I manually fill with water it will drain the water during this process.
If the stop/cancel is pressed after selecting the wash cycle all lights clear and the unit does nothing. If the stop/cancel button is pressed again it will indicate cycle 2 and run 30-60 seconds then indicate cycle 1 for 30-60 seconds then stop. I can here the pump running and if I manually fill with water it will drain the water during this process.
When running the above mentioned cycle 2 and 1 if the stop/cance button is pressed it will clear all lights and stop the unit.
Thanks for any help with this unit…
