kitchenaid middle spray arm
ordered middle spray arm and supply tube kit…when you put the split ring onto the supply tube, it doesn’t fit all the way into the hole in the spray arm…are you supposed to jam it in there? the notice with the parts said to use all parts…help!:confused:
yes, thank you, that’s the part, however it doesn’t "lock" all the way down into the spray arm…is that how it’s supposed to be?
