KitchenAid Mixer K5SS speed
I inherited a KitchenAid Mixer from my mother and it’s more than 20 years old. Recently the speed control went haywire so it now has only one speed - too fast with a regular surge from fast to slightly faster back to fast etc… Is it the speed control plate or the Speed Control Phase board that should be replaced? I hate the thought of just throwing it away.
Can you see it dripping water from the icemaker, and if so, where exactly is the drip coming from, (front housing, back where the fill cup is, middle?) and is it a constant drip?
Is it leaking into the back left corner of the ice bucket?
Any suggestions?
I would pull the water solenoid out, unplug fridge and remove outlet hose from the water solenoid. If dripping, you have a partially clogged screen, or something got jammed inside the valve.
My dryer wont get hot and there is an E1 sign that pops up. I changed the fuse-thrml and that did not work so what do i do?
:slight_smile:
— Begin quote from Lee A. Muhammad;127495
My dryer wont get hot and there is an E1 sign that pops up. I changed the fuse-thrml and that did not work so what do i do? Please help me with some answers.
— Begin quote from Lee A. Muhammad;127498
:slight_smile:
E1 is not a thermal fuse its for an open thermistor.
