I just found out that the motor on my KitchenAid KUDS01IJBT1 is dying. Replacement cost is about $450 including parts and labor.
The motor itself is only $115 on this site.
So… I’m not bad with a wrench, but I’m also am man enough to admit when
I’m out of my league. Is this a DIY job or not?
Also, if I’m replacing the motor, are there any other parts I should buy "just in case" or because they always get swapped out at the same time?
Thanks in advance!
Leon
Gene
2
Hi Leon,
This part is not too difficult to replace yourself. You can find the complete instructions in the [AP3039198](http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208533399.pdf"]service manual[/URL].
In addition to the motor assembly you probably have to order the volute seal.
Here are the break down diagrams for the Kitchen Aid dishwasher http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=127795&&model_id=503822
