Kitchenaid oven problem
The oven will turn on but cannot be turned off without re-setting the circuit breaker for the entire oven/stove top. Also, the keypad numbers 7,8 and 9 do not work so certain temps cannot be set. the oven thermostat works properly but is missing the numbers 7,8 and 9 as I said above…
Can you suggest what parts may be needed and the repair process?
Thank you!
